'39 Pontiac w/ '76 Mustang II front end, Olds 306 engine, 350 Trans., power steering, small a/c unit.
Shocks are wore out, and I'm sure coil springs need replacing as well. Car really BANGS when I go
over even shallow recesses....shocks only show a MAXIMUM of 3/4" travel at normal "sitting" position.
Weighed car at truck stop scales....1,800# front end. From investigating, everything points to needing
coil springs to be at 450# rating, w/ 1,800# load.
Closest I can come to the above specs is coil springs w/ 364" rating, with 1561# load rating. Obviously
I'm basing choices by staying w/ 3.50" spring I.D., as the top locator for the springs require this I.D.
I haven't been able to find ANY place that can take the spring & put it in a press with a gauge to tell me
what the existing springs are rated for......not that it REALLY matters, as I'm going to replace them
regardless, but I'd like to know just out of curiosity...as I have no way of knowing just what engine and
other options were in the car that this front suspension came out of.
I'd appreciate ANY input/suggestions for obtaining the soil springs I need!!
