I have a 85 305 H.O. Chevy. When it is cold or has been sitting overnight or a long period of time the engine backfires down out the exhaust. Took the exhaust off. Now running open headers and I see blue flames every now and then coming out the headers so far just the drivers side. I Also have light glowing on 7&8 exhaust tubes. I put a laser heat reading gun on the tubes (Drive side 1&7 run about 320 Degrees 3&5 run about 410 Degrees) (Pass side 2&8 run about 410 Degrees and 4&6 run about 320 Degrees) Not sure if this is normal or not. But I have done the timing and its good. Fires right up but backfires real back, now after it warms up its seems to go away, but with a little flutter happing. Now can anyone tell me what maybe is going wrong? Is it Burnt Valves or is the Carb out and need rebuilt or somthing else? Thanks!
P.S. Just put new spark plugs and wires on it. All new MSD set up.
