What would be the easiest way to hook up my Combination Valve"s "Brake" warning light switch? Thanks, Dana
The combo valve is the ground portion of the circiut. Power goes from fuse, to light, to combo valve. As long as hydraulics are good, the valve has no ground. After a hyd. failure, the combo valve provides a ground for the light.
Fuse needs to be switched from ignition, so power is NOT applied to circut when switch is off.
''....the valve has no ground"
I meant the light has no ground.
HEY 39: They make a little simple lever actuated switch that works off pedal position for about $ 20.00. I have one in my street rod and it works great and trouble free....DAVE
Discussion Starter #5
I am going to hook it off of my pedal brake lite switch, probably what you did also, seems easiest to me.
