If my 350 sbc has 8.5 compression with 76 cc heads, what will my comp. be if I change to 67 or 64 cc heads? I know there is a formula to figure this out be for the life of me I can"t find it. Here is my current set up Napa rebuilt long block with 882 heads (been told these motors are bad about having less than advertised comp.
), Comp cams xe268h cam with matched springs, RPM manifold, 650 edelbrock carb, 1 5/8 long tubes, 2.5 pipes with balance pipe, TH 350 with shift kit stock converter in a 3300# 72 Nova with 3.08 gears. I now a new converter is needed, thinking 2500 stall any suggestions? and the gears going to be changed to 3.42. This is a daily driver that gets played with on the weekends. Thanks for the help.
