Hello,
Well my motor was rebuilt 2 summers ago and I have probably put 500-1000 miles on the engine but because of a possible blown head gasket (engine is pressurizing the cooling system) I did a compression test and now I am wondering about the results.
Basically most of the cylinders were 145-155 on a dry test and one was 135 except for the cylinder that I think the coolant is leaking into. That one is 175, bang, right on the first dry test. So, that's why I suspect that cylinder has coolant sitting in it.
My main problem is that when I squirted oil in the rest of the cylinders, only the one beside the 175 shot up to 170-175. The reast seemed to max out at 155.
So why are only 2 of my cylinder up to 175 on a wet test? Is this telling me that my rings still haven't set yet or are the valves leaking 20% of my engine compression?
Are the rings still seating?
Just looking for your thoughts....thanks, Greg.
