I need help! My wifes '94 Buick LaSabre is not running properly.
She pulled into the driveway and turned the car off.
1. The heater/AC fan kept running on high even even she turned the car off. The fan won't cut off now unless I unplug it.
2. She went to turn the car back on and it wouldn't start. I unscrewed the battery and reconnected the terminals and it cranked but several things are wrong.
A. When I put the car in drive its in 3rd gear and won't shift down to first. I can manually put it in first, second, then third but it won't do it automatically. It also will not go into overdrive.
B. The radiator fans will not cut on. I found out this the hard way but thank the Lord it didn't crack the block.
I found the "engine control computer" from the parts store for $100.00. Has anyone had these same problems? I appreciate any help as this is the only vehicle I have that my family can all get into (3 kids). Thanks.
