Ya build what ya got. The Briggs is governed at 3000 rpm Wot won't exceed that regardless of load and will maintain that as long as It doesn't run out of power. without a large tank it will run almost continuously so I won't be incorporating a throttledown. Projected comp life is 20,000 hrs, I should live so long. System unloader is adjustable from 90- 175 psi. will set at 125psi as that is all that is needed and will give a slight increase in cfm. This is a piston valve compressor (unloader holds valves open) and has a pulse tank drain so it doesn't start against a head of air thus no shock load. There is a oneway downstream from the pulse tank to prevent backup.
Actually, its just a larger version of one I already built. The existing one (20cfm)uses an electric clutch and governor as an unloader but also has the pulsetank drain to prevent shock loads. A second governor runs the throttle down. Set to throttle up at 5psi before loading psi and down at same psi as unloader.
Its all fun and games till somebody puts a
marketable idea out then its everybody for themselves
