Gents, Thanks, Thanks, Thanks!!!!!!
Gentlemen, Many THANKS for the insight. I'm grateful to have had your input before I made the wrong choice. I've decided to go with the Scat 9000 series cast crank & I-beam (pressed rods). Only looking to get 375- 400 hp out of the engine, as this 86 scottsdale stpsd project is very important to my son & I. Combo is as follows. The 305 has been put on the shelf. I acquired a 95 350, will torque plate bore it 30 over, speed pro f/t two valve pistons, plasma moly rings, vortec 906 heads (jegs), perf prod crosswind intake from south_sales/ ebay (similar to edelbrock rpm air gap), holly 750 quick adj vac sec w/ 68 primary jets. billet msd hei coil in cap, hooker comp headers also from jegs. Also jegs self align, centerbolt v/c aluminum roller rockers. Still working on a cam choice, I've run the comp cams magnum 305,& 280 dur cams in the past. I 'm leaning towards the 270dur / 470 lift. Not quite as choppy as the 305 & 280 but should still give some rumble in the jungle & be ok down low to mid. Block is roller ready/ but we're going to stay with hydraulic flat lifter to keep cost down. All thats left is machine shop prep, ordering crank, rods, flywheel & balance. Again, You are gentlemen & scholars!!! Todd
