1 - 2 of 2 Posts
I have just replaced a thermostat the bottom hose leading to the thermostat housing and had to use a Polly to seal the thermostat housing when i started the car and let it heat up i had water coming from my cap the thermostat is new and just after replacing it i noticed a leak in my hose this is when i changed it that when the car had water coming out from the cap. do i have air in the engine or do i have to replace the thermostat again
I think you ought to re read your post and modify it.
It´s hard to understand.
You´ll also have to post up what vehicle you´re working on.
1 - 2 of 2 Posts
