I am trying to decide what would be the best choice for a suspension redo for the 53 olds 98 we have. I am considering a corvette front and rear. is this a good choice or am i barking up the wrong tree. We are planning this to be our long trip car and want comfort and safety in the ride. Anyone gone this route? Thanks!
Crazier By The Minute
I had 81 Vette rear suspension on a 31 Ford coupe. It did not ride very good. Also I have owned 4 Corvettes the newest being a 79. None of them rode well either. I doubt if Corvette suspensions will be heavy enough to carry the weight of your vehicle. Bud
For some reason everyone thinks Corvettes are lightweight cars. Heck, a modern Firebird weighs more than a 57 Chevrolet 2door sedan. A 53 Olds may be a match for a Corvette. Check your title and see what the registration weight is, then check Corvette websites and see what they weigh. If the figures are within a couple hundred pounds either way and you like the idea..DO IT.
The suspension on the front of your car, rebuilt correctly would make a very nice driving and handling long distance cruiser. There should be some easy way to convert to modern disc brakes. Same in the rear though the springs (parallel leaves, yes?) may need replacing or at least rebuilding.
If that is not a go deal, a rear steer 68-74 Nova front clip may be the answer. Go for a 74 if possible, and don't just look under 2door cars either. We got a super nice disc brake, power steering clip from under a plain jane granny Deluxe 4door sedan.
Philippines Cowboy
I'd rebuild the stock setup for a street car. The only thing you'd gain with balljoints would be anti-dive and that's not that big a deal.
Discussion Starter #5
More on 53 olds suspension
I am easily convinced! I have found a place to get what i need for the brakes and i think a steering upgrade can be had as well. The only concern i have is the original knee shock system. Has anyone run across a shock obsorber conversion for the front end? Thanks!
