I have a 327 67-68. I am trying to install a serpentine belt system from a 1989 5.7 camaro on it. I am wondering if i can use my powersteering pump of a 350 with just a serpentine pulley and i am also wondering the 327 has the thinner harmonic balancer and if i install a pulley on it if it will bolt up even with the system?
Also wondering if you guys know the guess hp of my motor. Its a 327 60 over trw forged pistons .125 dome. i thin they are 10.5 compression and i am running corvetter heads that are 1.94 valves with 76 cc chambers i believe maybe 74cc. Aluminum roller rockers on the heads. I am running a edelbrock performer intake. 750 double pumper holley. The cam is a solid tappet 480 lift 280 degree compcam. solid comp cam lifters. any other info i am missing i can provide? going into a 75 nova. 350 turbo tranny and i am probably going with 3.73 gears..
I pick this site because it seems you guys are the smartest guys with the most correct info in your threads.
Also the rollers are 1.60
