left a block outside with water in it over winter cracked by freeze plug go figure my bad will post picks later can it be welded? :evil: :evil:
IMO, unless it's an expensive aftermarket block it's not worth taking a chance on welding it. I would look for another good core.chevy bb 572 said:left a block outside with water in it over winter cracked by freeze plug go figure my bad will post picks later can it be welded? :evil: :evil:
Bummer Dude, what block? I did that once to an engine, I kept the two pieces from the side as souvenirs. Sad part is was all fresh and still in the garage never made it down the road :smash: Like said about a new block as you only know about the crack you see. What if into the cylinder wall or other area? You could probably pick one up at a boneyard and make do. :spank:left a block outside with water in it over winter cracked by freeze plug go figure my bad will post picks later can it be welded?
