Hello, iam in need of ideas on how to vent my crankcase.
My set up is a 355 with a 6-71 blower, and dual holley 600's. It pushing around 600hp. The engine has breathers in both valve covers.
My problem is it is pushing oil out of the breathers, and making a mess under the hood, plus burning onto my headers. Also pushing out the valve cover gaskets.
I would like to run a pcv valve, as i have been reading alot about it on here, and seems the best way to go.
My question is, do they make a pcv valve that fits the grommet size of the breathers, or do i need to drill another hole in one of my valve covers?
Also if i do need to drill for the pcv valve, do i need to block off the hole, and not use the breather on that valve cover?
Do i just run the vacuum to one of my carbs, or do i need to (T) the line to both the carbs?
Will this be enough to give me proper ventilation?
The car is a street car, (just a weekend cruiser) but sees alot of high rpms, 3000-7000+ rpms quite often. It has 456 gears, so rpms are always high.
I have read about the catch cans off the breathers also, is this an option i should look into, if the pcv valve is out of the question.
I have mufflers, and pipes back to the rear axle, so i don't think running it into the exhuast will work do to backpressure issues.
Any advice on the best way to set this up would be greatly appreciated.
Thanks,
Daryl
Thanks,
Daryl
