I have an 1988 Camaro that i put a 327sbc "race" motor in.
I solved all the problems: gears, carb, timing, intake, the works.
But no matter what i do, i suck oil through the pcv valve. :smash:
The heads are 462, so the bolt are on the outside.
I have tried 2 sets of valve cover (both with baffles), one set of edelbrock stamped steel, and one set of plain cast aluminum tall style. I have even made my own PVC breather tank, but it fills up to fast and oil still gets into the engine. It take about 200 miles to make my plugs look pretty bad. I even went aside and got high pressure braided clear tubing just to see the stream of oil being sucked through. And the pcv valve itself IS working properly.
On cold start and idle you can't see any oil being sucked through the clear tube, but if i get on really good for a minute and then open the hood you can see that leftover oil flow through the tube into the intake.
Is there a way to use a smog pump or vacuum pump as a PCV system and separate the intake from the pcv valve???
I tried driving with the pcv unhooked, and it just made an oily mess in the engine bay, but the plugs and intake runners were cleaner.
Any ideas, tips, suggestions would be really, really appreciated!
