Looking for a little advice, I am building a Ford 5.4 DOHC mod motor with a 6-71 supercharger. I am using an EDIS 8 setup with a Microsquirt configured for control of ignition and EFI. I am just getting this combo running and solving some problems. The first is a kicking back/backfire issue when cranking the motor, the setup right now is basic configuration of the Microsquirt so I am assuming the timing displayed in the TunerStudio of 10 degrees BTDC is accurate. It is acting like that 10 degrees is too much advance and is firing too early, I know this value can be adjusted using the software but I wanted to get some feedback before making any changes. I have reduced the cranking advance to 3 degrees BTDC and it is still kicking back against the starter. My cranking speed is a little low at 145 rpm. Roots superchargers do not like backfire so I need to solve this issue before I move on.
I do have a video of the backfiring if that will help. Once it starts it seems to run fine.
