I finally finish a restoration on my 1984 Chevy C-10, I have been road testing today and noticed that after driving the truck for about 20 or 25 minutes and turning off, to buy food for my dogs, I had to cranked more than normal to bring it back to life.I turned off a couple more times before getting home and the same thing happens. Even I did not smell gas, neither the carb shows any overflow, I had to floor the gas pedal every time I had to start the engine. This did not happen when truck is sitting overnight and I turn it on. This truck doesn't have the emissions control system from factory. Charcoal canister was eliminated and the fuel return tube was capped, same thing with tube to the charcoal canister. The stock fuel pump was substituted by an Edelbrock "Victor" Fuel Pump, 110 gph- high volume that produces 6 psi and doesn't require a regulator. The engine has also an Edelbrock 600 Performer Carburator and intake manifolds. Any similar experience with fuel pump and carburator similar to mine? Thank you for your comments.
Luis
Luis
