Bought a used engine , guy said 383 bla bla bla so I took a gamble and when I got home tore it apart , everything was looking 100% until I dropped the pan and saw some color on the crank , so i pulled the rod cap to make sure it was fine and bearings and crank grind look perfect no wear or color , looks like at one time it spun a bearing so they ground the crank and re used it , crank is an eagle , pistons are probe flat top's and rods are unknown , I don't know what to do now ? Loosen all rods are re torque ? seen 45lbs with oil and 50lbs with lock tight ? bolts are 3/8 24 fine I believe
