350 sbc stock block. machine shop I bought it from said it was a high nickle content block.
-Victor Jr 215cc heads 2.08 / 1.60 set up for solid roller
70cc chambers
-vivtor jr intake with port matching
-850 might demon carb, may be overkill
-wiseco .040 over pistons for 6 inch rod 8cc dome
I think it is around 11:1
-6 inch small journal eagle h-beam rods
-summit brand roller rockers. I have heard they perfrom well
-stud girdels
-crane push rods
-comp solid roller lifters
comp cams solid roller cam
gross valve lift is .575 intake and .575 exhaust
duration at 50 thousands is 300
lobe seperation is 110 at .050
-lifter valley vents, I am unsure if they are ok for some street
-small journal nitrite crank
-sealed power bearings throughout the motor
-crank scrapper, unsure for street use
-stock oil pump
-holley blue fuel pump
-8 AN braided fuel line from the tank to the carb
-stock oil pan
-crane pro series billet timimng chain set
-cam button
-electri water pump
-felpro head gaskets, the ones reccomended by edelbrock
-arp head bolts
-I used stock main bolts and they are not splayed
-700r4 tranny built to handle 700-800hp
it ahs the beast sun shell and a full manual reverse valve
body from TCI so not tv is needed
-28-3100 stall converter
-hedman headers for the s-10. long tube 1 5/8 primaries and
3 inch collector
-msd pro billet distributor
-msd 6 box
-msd 4 stage digital retard
-edelbrock rpm performer nitrous
-msd coil
-sfi balancer rubber band not a fluid filled any advice.
what should I expect from this motor. I can change some small things but I can't afford to change heads or soemthing that expensive now. I have been thinking of getting the new crane shaft rockers that have the poly matrix bearings, has anybody heard anything about them. please be honest if something is just waiting to break my motor and destroy it. please let me know so i can try and get it fixed.
any recomendations on a gear ratio.
I had it balanced. should the piston pads have any drilling to balance them. what I am asking is how to tell if it has been balanced without having a balancer it looked like some pistons were never taken out of the packaging for balancing.
once again thanks for any advice.
the points I think that may be weak. mains since they are stock bolts and not splayed, the lifter valley vents and the crank scrapper.
this truck will see approximatley 35 miles per week....
70cc chambers
-stud girdels
-crane push rods
-stock oil pump
-stock oil pan
-cam button
-electri water pump
-arp head bolts
3 inch collector
-msd 6 box
-msd coil
