1 - 2 of 2 Posts
Hi there.
I have a 1975 chevy c10 ive put a 95 lt1 motor in. I'm currently trying to run my fuel system.
Can I use the old fuel line to connect to the motor. Fuel line? Or how should I go about hooking up the fuel lines?
I have external fuel pump. Filter and return fuel regulated filter.
Any suggestions?????
Sent from my LM-Q720 using Tapatalk
True Hotrodder
I think the question is how much of the LT1 is stock - all of it? If so, then it's probably best to try and duplicate the fuel line system that it had from the factory as far as fuel pump and filter. That engine needs something in the mid-40s PSI, probably drops a bit after starting.
1 - 2 of 2 Posts
