mitmaks said:
which ones should I go with? It would be easier to install glue-on ones but if theyre not perfectly glued they would leak grease.
Only use a screw- or glue-together "split" boot if you are not removing the shaft. They should be considered a temporary fix- they do not last anywhere near as long as a 1-piece boot.
If the boot's been damaged long at all, all the grease will have been thrown out, dirt will have gotten in- and the joint is (or soon will be) history. Check to see if the grease feels gritty. If it does, replace the joint or shaft. If the shaft makes any noise (clicking on turns, clunking, etc.- removing and replacing it now would be the best bet, IMO.
If the boot just got damaged and wasn't driven any distance, a one-piece replacement boot is always better than any of the stop-gap split boots. But better still is to just replace the shaft and be done w/it.
