The “D” is nothing more that an identifier for the die that was used to forge that and probably thousands more. Look at the long shank if it has been flash ground smooth and shot peeled with 7/16th bolts your on to something special though probably well along in its fatigue life.
The production L82 got “pink” rods, these are production mild steel 1046 or 1053. These were shot penned but use the 3/8ths bolt unless some shop did some custom work.
I rather think based on expensive experience that the factory bolt and nut rods short of some speciality Bowtie 4340 forgings I would agree with Imsport that expecting these to hold up to 500 horses is a “Bridge to Far”. I mean it’s a crap shoot at best and one where your betting the entire engine and all the money that is contained therein for parts and services.
Rods are the highest loaded item in the engine and are high on the structural failure list. The bolt connection is one of the most common failure points and much of that has to do with the mated section design outboard of the bolt. The high loads at high power and RPM are stretching the cap in the downward direction. This is trying to open mate of the bolted parts from the inside. The bolt is put in shear bending which is the weakest direction for strength. The load is transferred to the out board pad which is usually too small on GM rods. The inside of the joint cracks open pinching an edge of the bearing into the journal. When this happens the bearing exposed edge squeegees the oil off the crank, the journal and bearing overheat and weld together and the rest is junkyard history.
Best advice these days is new rods with modern ARP cap bolts into the shank (no nuts) and with locating dowels a ring the bolt to help pick up the shear bending load from the bolt shank and spread it over more area, in other words increase the load carrying capability that is resisting the cap pinching the bearing into its journal. For desired your power level this would be my minimum choice rather than use some mixed batch of old rods for which I have no history.
Scat 25700716: Pro Series I-Beam Connecting Rods Small Block Chevy - JEGS High Performance
But while I’m willing to bet with my life, I try not to with my engines.
