I got a 85 cutlass supreme. All around its in pretty good shape. The one thing i dont like is the vinyl top it has on the back. I think the body would look better just being smooth. Does anyone know if these vinyl tops can be takin off. Also how would be a good way to remove it?
Just rip it off. If your throwing it away you don't need to take care in removing it. After you get the top off you will need to grind,cut off the little metal studs across the roof and smooth with a bit-O-filler and repaint and your done.
HK
