Got a dart 434 and found this bad rocker today while setting the valves. Never seen one do this before. What may have caused it? I'm running 1.5 on exhaust and 1.6 on intake.
It's a blown drag car. Should I buy 1 rocker or get a whole set. If a whole set which ratio would be best? See included engine spec sheet.
Dart 434
Bore: 4.155
Stroke: 4.00
Compression: 8.6
Comp Cams roller cam
Intake lift .637
Exhaust lift .631
Duration @ .020 intake 300 exhaust .302
Valve timing @.050 intake open 21 BTDC close 63 ABDC
Exhaust open 71 BBDC close 13 ATDC
Installed @ 111.0 center line
Duration @ .050 intake 264 exhaust 264
Lobe lift intake .4210 exhaust .4210
Lobe separation 115.0
Brodix track 1 cnc 227cc heads with manley valves and springs
Weiand 6/71 blower .12 over drive
Twin Holley 1000 CFM HP carbs blocked power valves #94 jets all around
NGK 4554 R5671A-8 plugs
Dart 434
Bore: 4.155
Stroke: 4.00
Compression: 8.6
Intake lift .637
Exhaust lift .631
