I was looking at valve stem seals and find there are many. And I am not real confident on this subject.
I took a look at the Dart web site, it says my heads are cut for umbrella seals. So is there any reason to do otherwise?
The guides have a 9/16" OD (.5625")with a flattened conical and well centered top.
One of the reasons I ask is that the valves and pistons were pretty carboned up. Engine has 5 years of summer use, mostly 2700 to 3300 rpm cruising. With some idle putts and a very few blasts to wide open, and near WOT.
But, I also need to confess this has been my learning experience engine. So it has been run rich plenty of the time which I imagine contributes to carbon deposits. AND, I am certain that I hacked the first umbrella seals as I put them over the valves.
One the one hand I'd like to not carb up my valves and piston tops, on the other I do not want to starve my guides of lubrication.
I should be better at keeping the products of combustion down now. I got myself an AFR setup and vacuum gauge last year and it made a lot of difference.
So, umbrella seals?
So, umbrella seals?
