I come here trying to save an engine in a vehicle that I have had half of my life. If I can't get through this problem myself I will have to do the dreaded deed of feeding it to the wolves (taking it to a garage) where they will no doubt charge me inaccordance to whatever they want, if they can even fix the problem themselves.
Whatever help I can get here will be deeply appreciated.
This is a Chevy Van 305 V8 with an hei ignition system that is producing no spark. I have replaced everything at one time or another. At this time it now has a pretty much new ignition system. New ignition switch, distributor (which came with a new module, pick-up coil and capacitor), new distributor cap and rotor and a new coil. There is also now new spark plugs and wires.
There is 12 volts present (with switch in 'run' position) at the connector which plugs into the 'bat' terminal of the cap. While trying to crank the engine it drops to around 10 volts. I would think this is normal, no?
Please help. I am at my wits end. Does anybody have any suggestions?
