having a tough time deciding on which carb i wanna run with.
its a toss up between the 650 speed demon and the 650 mighty demon, both vac. secondaries. I'm leaning more towards the speeddemon for the cheaper price
here are the specs on the drivetrain currently:
355ci
10:1 Compression Ratio
Holley systemaxII alum. heads
Comp cams 270H magnum
Holley street dominator intake
MSD Pro-Billet distributor #8361
MSD Blaster2 Coil
MSD 6AL Ignition box
Edelbrock Thunder Series 650cfm AVS carb
Aeromotive Billet Fuel Pressure Regulator
shortie headers
K&N 4" Open Element air filter
3.73 gears
Eaton Limited-Slip Diff.
Th350 transmission
2800 stall torque conveter
B&M Stacked plate trans cooler
trans-go transpack
355ci
MSD Blaster2 Coil
shortie headers
3.73 gears
Th350 transmission
trans-go transpack
