Is a product like POR15's Marine Clean a good enough degreaser to wipe down an area before putting bondo on?Will paint reducers or varsol work as well?I am going with the filler under the epoxy,right or wrong, on my fenders.After filling and sanding,should it be wiped down again with a degreaser before the epoxy, or could that hurt the filler?The fenders and eventually the rest of the car will probably sit with the epoxy on it for a year or so, while the rest of the car is built.Latter I plan to go over everything again with a high build primer and block sand to get the body straighter. Is 180 course enough to get the high build to stick to the "cured" epoxy when I get to that point? Thanks,Jim
