Hi,
I'm putting my engine together (351C) & I'm having problems degreeing the cam. Its a hydraulic flat tappet cam. This is what the cam card says;
Valve timing @ .050" lift;
Int. Open 8 ATC
Int. Close 22 ABC
Exh. Open 37 BBC
Exh. Close 13 BTC
Now these are the readings I'm getting;
Int. Open 10 ATC
Int. Close 23 ABC
Exh. Open 35.5 BBC
Exh Close 12 BTC
I've tested, retested & tested some more. I get the same numbers. I've spun this motor so much that I think the rings are seated. So are these numbers normal? I thought that if the cam was off, it would be off the same amount across the board, not different amounts.
Any help would be appreciated.
Thanks!
Int. Open 8 ATC
Int. Close 22 ABC
Exh. Open 37 BBC
Exh. Close 13 BTC
Int. Open 10 ATC
Int. Close 23 ABC
Exh. Open 35.5 BBC
Exh Close 12 BTC
Thanks!
