1 - 6 of 6 Posts
Got Ouzo for touzo
I had it done to a old VW beetle I did California style. I had a friend at the glass shop do all the measurement and cut it. But my beetle had flat glass, newer cars would be harder to do. Does your ride have flat glass side windows? If so it should be easy.
Good idea by the way, they do look a lot better tat way, in my opinion.
bonuts
If its flat glass, make up a full size template out of ply. Use about 4mm or 5mm thick as this is how thick the glass will be. Then when you get your template and it fits good, take it too a glass shop and ask them to cut it, bevel the edges, and then temper it. You can also get it tinted if you want.
Did it to my Henry J < and it was easy- mocked up template out of 1/4" masonite and took it to the glass shop and had the pieces cut. Ran power windows so had to extend the channel support for the bottom of the window to keep it level in the track. Works great- no whistles or leaks yet... Yes they DO look a lot better w/out the outdated vent windows in my opinion. :cool:
1 - 6 of 6 Posts
