Here is the set up:
502 with Hyd. roller comp cam (Big Mutha thumper) AFR 305 heads, Mighty Demon 850 with 3.5 power valve and jetted at 80-83,Air Gap intake, MSD 6AL, coil and dist, the plugs are gapped at 50. The inital timing is set at 15 and vacuum at idle is 8-9.
The problem is that the motor is very rich, plugs are black and when I first start the motor it will hardly run and pops through the exahust if it has set for several days. The motor clears up after I run it around 2000 rpm for a few minutes. When I drive the car it smokes and really pours the smoke when I open it up, very rich smoke. Jetted down 3 times so far. I pulled the carb and replaced the power valve that was a 7.5 with the new 3.5 and found no leaks. I also adjusted the butterflys to the correct opening. The floats are set just below the center mark and this is where things get strange. After the car sits for a day or so and I look through the site glass I can see no fuel in the bowls, the float is below the window. I ran the car up to temp, pulled the carb with fuel in the bowls and set the carb on a stand and let is sit there for 24 hours. Today I go out and again the fuel level is below the site glass but no fuel leaked out of the carb onto the white paper I had below it. The fuel has to be going some where because when I fire the motor it is almost flooded with fuel which I think makes the backfire through the exhaust. Where is the fuel going??? I never had this kind of problem with a Holley and may have to ditch this new Demon.
Any ideas?
Any ideas?
