Thought this was going to be sweet, but now very very very upset. 350 vortec heads, small cam (isky 262/270) 3:73 gears 31" rear tire. I installed an OD tranny over the weekend and it seems to ping at 60mph on the hwy. One other change I did was change distributors to a MSD street fire. Something needs to be adjusted inside the vaccum module. Have not done that yet.
Anyway, my biggest problem is how do I get rid of detination to enjoy the added expense of the OD tranny I just added. Also added a 1800-2200 stall with this set-up. I have always run 91.. so this is not it.
Also, I have never had a distributor where you adjust the advance through the module. Is this common and DOES it need to be adjusted. I have not touched it yet.. and instructions say to use a 3/32 allen key to adjust. First start by turning clockwise (in) then out to adjust. Has chart.
I am seeming not to be able to enjoy the OD feature because of the pinging. Even when I try and pick up speed.. it gets worse.
