1 - 1 of 1 Posts
10-12-2017 12:05 AM
URL:https://bestaircompressorstore.com/dewalt-dwfp55126-6-gallon-165-psi-pancake-com...
Description:DEWALT DWFP55126 6-Gallon 165 PSI Pancake Compressor Review
If you're searching for a Compact compressor, square measure|you're} within the right place as we tend to are planning to gift you with DEWALT DWFP55126 6-Gallon a hundred sixty-five PSI griddlecake Compressor! however tiny dimensions aren't the sole sensible issue regarding this machine because it is as powerful because it is compact! a trifle bit later, you'll perceive what we tend to mean by that.
But as air compressors aren't regarding their size solely, we are going to review the subsequent options of this model – pressure, capacity, overall performance, durability, noisiness, movableness, and its further instrumentality. Besides, we are going to answer to some commonly asked queries. Now, let’s begin the review of DEWALT DWFP55126 6-Gallon a hundred sixty-five PSI griddlecake Compressor!
Capacity
Capacity is that the second base feature of air compressors. within the case of this model, the capability of the flow of compressed gas is two.6 SCFM at ninety psi. Combined with the 6-gallon tank, this may permit you to perform most of the tasks uninterruptedly. however detain mind that whereas the 6-gallon tank is kind of voluminous, it won’t be quite enough if you have got an enormous range of tools or predict additional continuous delivery of compressed gas.
Noisiness
For some users of air compressors, the background level is kind of a major feature. If one doesn't need to own a loud machine reception which is able to, besides, hassle the neighbors, searching for a quieter mechanical device could be a necessity. And with DWFP55126, it becomes quite realizable as its quiet motor produces solely seventy-five.5 dB of noise! whereas you'll suppose that it's not that quiet and there area unit additional calm models out there, 75.5 dB is truly superb for a mechanical device delivering a hundred 65 psi of grievous bodily harm pressure! what number alternative such models you know? Not that a lot of for sure! That’s what makes this Dewalt 6-gallon air compressor one in every of the most effective quiet machines you'll find!
Portability
Although the 6-gallon tank could also be poor for you, an enormous advantage of smaller tanks is that the raised compactness of air compressors. And DWFP55126 isn't AN exception! it's not solely compact however very light-weight likewise, consideration solely thirty lbs.! however this compressor wouldn’t be therefore transportable if it didn’t have a convenient handle for simple transportation. If you're planning to carry your compressor around your house and back and forth between the room and therefore the worksite, this mechanical device is for you! It is called the best model of a portable air compressor.
The Great Feature
* 165 psi of max pressure is enough for the most air tools and tasks.
* The motor can start up even in cold weather.
* The compressor delivers 2.6 CFM at 90 psi of compressed air.
* Two couplers support two air tools simultaneously.
* Oil-free pump is maintenance-free and delivers cleaner air.
* High flow regulator to maximize the tool’s performance.
* The noise level of only 75.5 dB.
* Extremely durable.
* Highly portable.
* Optional brad nailer kit.
* 3-year limited warranty.
Category:Air Compressors
Tags:None
User: olivialisa (View All of olivialisa's Links)
Send to Friend
1 - 1 of 1 Posts
