hey everyone! i have a weird prob.. 95 dodge ram 5.9 magnum. when i start it it runs rough - horrible. as it idles the check engine light comes on. a while back i caught the intake on fire looking for vacuumn leaks ( appropriate - since i had to replace them all after that) anyways i melted a little bit of a fuel injector plug and wire protector. . later when plugged into a snap on to dial in my distributor (cam sensor) fuel syn to +4 degrees i noticed the #2 injector had an intermittent circuit fault. coincidently - the book doesnt # the injectors, but the burnt one is on the same cyl as the #2 plug. this is the only code coming up also.. and the worst symptom other than a cold start bad idle is a throttle hesitation when stompin on it.
more info - im running one step hotter plugs to kill detonation. think it getting colder this afftect anything?
Q1 - anyone know if the fuel injectors are numbered the same as the plugs/ cylinders?
Q2 - where the heck would i obtain the connector with its 6 inch 2 wire lead? (not the dealer) junkyards here suck btw
thanks to those who reply
