First off, the SPI products are the best I have ever used hands down, their prices are reasonable and customer service are second to none. As for base, you will likely get several different answers for different people. I have had good results from PPG Deltron, Standox, and R-M for base colors. I have not had the chance to use any, but I have heard good things about Pro-Spray and Wanda base coats as well. As already stated, I would also recommend using a sealer prior to base to get even coverage. I don't know if they still offer it or not, but R-M used to mix sealer in a color close to the base color to help with coverage on the highly transparent colors. If that's no longer an option, I would probably use a gray sealer or possibly black depending on if you want the paint a little lighter or darker when finished. For primer, sealer, clears, reducers, and cleaners I highly recommend SPI. I recommend their base coats too if you need one of the colors they offer. I used to use PPG 2021 and 2002 clear coats and switched to SPI, never looked back.:thumbup:
Kelly
Kelly
