1 - 1 of 1 Posts
Born 13th Generation U.S.A.
Hello all, I would like to know if between the two trans when bolted to the Motor is there outside "Shift Control Shaft's " in the same places measuring from the bell housing mounting point at the motor back to the shaft?
My question relates to/for all the OEM linkages set-up points from frame mounted bracket/s to the trans shift control shaft locations?
I have a 68 C10 with a OEM 69 C10's auto steering column that has been modified for 4 sp OD shift points (I hope). I'm not for sure if the T350's Column to frame linkages in all will mount or couple up to the Transplanted 1992 4L60 trans outside shifter shaft?
What say you all or do I need to explain more. (Edited)= I did go back and edit my original wording, think it makes better sense.
1 - 1 of 1 Posts
