I'm a Ford guy that Ended up With a 1968 Chevy C20 Pickup, Currently it has a 307 Chevy (Origional engine) and it needs a rebuild bad, The trucks been a daily driver since it first rolled off the lot back in April of 68... The Truck was a gift from my grandfather (origional owner, purchased new) and I've been trying to restore it for a year and 2 months now.
I know the Bore and Strokes on the 307 are Different from the 327 and 350's, and as far as I know the only differences between the 327 and 350's was the Crank and 327's were only offered in 2 bolt mains...
Well my Major question is, Will the flywheel and clutch from a 307 Chevy (NP435 4spd Manual) Bolt up to a 327 or 350? Or will I need a new Fly wheel?... As far as I know the block I'm going to get is Internally balanced, and my uncle's (Chevy Fanatics) all say everything should interchange...
If I have to I can use the 2 BBL Mainifold and carb from the 307 Right?
(Carb Was recently rebuilt)
And my Truck came with the HD Radiator, and its specs are the same as the 350's specs except mine was only 1.5 - 2 inches smaller, I was told that this will handle the 327 / 350 Just fine... True?
How good are the 327's , I've heard amazing stories about them but the thought of only 2 bolt mains and about 300 HP / 360 TQ (Projected) sounds a little scary...
I'm on a LOW budget, so any tips you guys can give me on this conquest? any help at all is GREATLY appreciated...
Mike
Mike
