I don't have any experience with Fords so this may or may not apply. Most roller cams are made from billet steel which is a harder material than non roller cams. The steel will eat up an iron gear. I've read that some manufacturers put an iron gear on their roller cams so they don't have that problem. I learned this the hard way. My distributor gear was worn down to a knifes edge in about 3000 miles. Chevy has a gear that they use on their roller camed engines. I haven't put many miles on it yet, but so far wear is minimal. I would think that Ford would also have a gear for roller cams. Crane (or Comp) sells a distributor gear for $100 that they say you will never have to worry about or replace. I wonder if it will wear the cam. That's my 2¢.
