So when I initially installed my engine I dropped the distributor in, set the initial timing to 15-16 and fired it up. It has run fine ever since. Never pings or stumbles and runs strong. I had thought the max advance was 34 degrees but messing around today I have no idea what I am doing.
I have the vacuum advance hooked to ported vacuum and while revving the engine slowly it seem to just keep advancing. I need to clean the damper marks but I feel like it just keeps on advancing the faster the engine goes until it’s at like 50-60 degrees. I have very little understanding of the recurve procedure or how you make it “all in” at 34 degrees. I have read so much I think I’m even more confused now. Do you check “all in” with or without vacuum advance hooked up? Can someone in simple words help explain what I should do please?
