1 - 10 of 10 Posts
I am not sure what the 85s are like, but does the 85 have computer controled advance, or is there a vacuum hose to the distributer from the carb?
With the 78 distributer, you need a vacuum line to operate the vacuum acvance.
rebelbill1972 said:
on my 1985 305 I,m going to swap the stock coil with a coil off a1978 model so I can do away with the computer. Are there any other must do things for this to work?
I don't think the coil has anything to do with whether are not the distributor is computer controlled. Don't the HEI distributors for computer controlled engines lack an advance mechanism? Seems it would be better just to swap the entire '78 distributor into the '85.
Bob
The only difference I know of is supposed to be some electronics, there is already vaccum to the stock dist.
Banned
the coil has nothing to do with it
the ECM controleld HEI has an extra wiring harness plug with four wires, flat connector, on the passenger side of the housing, as installed in the vehicle
good luck
Discussion Starter · #9 ·
distributor swap update
Ok now that I have the distributor in my paw, as mentioned before by fast68, the only difference on the distributor I picked up (from a 77' suburban) and the one in my 86' C-10 is the wiring harness on the passenger side(that I assume goes to the ECM, I haven't had a chance to chase it yet).
I was told to install the 77' dist and unplug the 2 wire connector on the front of the carb. does this sound right? What about the electronic choke? Will it still function without the ECM? Also, will I need to make any adjustment to the carb or should I plan on replacing it?
Doc here, :pimp:
Since it is carbed, all you need do is install the Dizzy, and plug the Ignition wire from the old coil into the "BATT" terminal...Check to be sure it is not a resistance wire,or have a ballast on it, and If you have a Tach, it goes into the plug marked "Tach"..that's it..
The Electric choke gets power from the alternator Field through a relay inside the car..If it is unmolested, changing the dizzy will effect nothing in that circuit.
IF you are doing away with the computer , You need to get a Q~Jet that is non computer compatible..(pre~80's), While the computer carb may run, It will get lousy gas mileage, perform badly , and stink from raw fuel just sitting..
Doc :pimp:
1 - 10 of 10 Posts
