I had posted a similar discussion to find anyone who has kinfe edge their crankshaft on their own.
I have a two cylinder crankshaft from a motorcycle that I am experimenting with. It is trashed so I dont mind messing with it and IT WILL NEVER BE INSTALLED.
I wanted to practice machining the crank to see how difficult it is. What I need to know now is:
HOw are the crankshafts balanced? Are the counterweights weight equalt to the weight of the entire connecting rod assembly?
In order to fine tune the weight balancing I have seen them drill holes into the counter weights then cap the holes off. Is this the best way?
I want to understand how the balancing process is done in order to determine how much I want to remove from my counter weights.
I want to have a well balanced crank in the end.
