Doc here,
imp:
On the Semitics I pulled for 94 full sized vehicles, I did not see a specification for a digital dash..(they don't tell you, the wires just say "---> to instrument cluster")
But on the third one I looked at, showed several taps to "instrument Cluster" from the power train module..as well as the Sensors. This one I suspect is a digital dash cluster..as opposed to the others that just show a lamp tied to switched hot and sender..
The Spedo, comes from the transmission transducer to the speedo head AND the VSS pin on the Power Control module..
The best way to find out, is get a manual for your car, and run down the wire colors V/s Pins on the Power Train Control module..If the module is "Inbetween" the dash and the sender/Sensor, you must use the module..OR look into an aftermarket interface kit.
Doc
imp:
