1 - 13 of 13 Posts
Hi Guys
Got this pain in the butt situation.
I replaced the STEEL FREEZE PLUGS that were placed in the body of my motor mistakely by my machine shop. WITH BRASS ONES.
After reading (maybe that my problem :D ) The reading said, "... Brass Freeze Plugs last LONGER than STEEL."
My problem is: I CAN'T FINE BRASS FREEZE PLUGS FOR THE HEADS :spank:
Presently, Steel Freeze Plugs are DEEP SET ONES in the Cylinder Heads.
The Brass body plugs I are shallow around the rims. The Steel ones in the head have a DEEPER RIM that set into the heard DEEPER.
Any you guys can figure-out this pain in the butt problem for me PLEASE.
WHERE ON EARTH CAN I BUY THOSE DAMN 'DEEP SET RASS FREEZE HEAD PLUGS" for my 289 engine :confused:
Thanks guys
GOD BLESS YOU ALL
Schooner :cool:
"The Brass body plugs I are shallow around the rims. The Steel ones in the head have a DEEPER RIM that set into the heard DEEPER."
Why would this be a problem.......?
As long as they seal the hole, I don't see a problem. Use whatever you can get....Brass may last longer, but the steel will probably outlast the engine.
Pioneer Barnes, Dorman, US Tool, are 3 suppliers of cup plugs.
Could look it up on Monday if need be.
Also see you live in Las Vegas(pretty big city) if you cant find a machine shop there that can come up with correct part number I dont know what to do.
Is this a small block Ford?
If you are concerned about rust you could scuff and paint the freeze plug (inside and out) with engine enamel - just make sure you wipe any paint off the "sides" of the plug before you pound it in.
Hey Poncho62
What the problem is; There's a reason why those head freeze plug are deep set. Other wise they would have put in the shallow ones. There's a reason for everything in this world. That's why?
I don't mean to be short with you. I'm just kinda talkin' to myself and sharing it with.
Thank you for your impute
GOD BLESS
Schooner :cool:
Discussion Starter · #8 ·
Hey Guy
YES, its a 289 Mustang engine.
If the machine shop has the deep set plugs, then why can't I get 'em from auto part suppliers?
Thanks for you impute.
GOD BLESS
Schooner :cool:
All 289 and 302 had the shallow plugs in there from factory. When you put them in be sure to get them past the little chamfered area. If one pups out that wont be too good for your engine.
I used to put the deep ones in because thats all I was given to use (didnt know any better either), theres still room for water to flow inside. The deep plugs will not come out easy like the shallow ones did.
Now I would want to do it right find the shallow cup plugs.
Discussion Starter · #10 ·
Hey Greg
I replaced the steel freeze plugs with; BRASS ONES.
And yes I did bang 'em in pass the champed part around the openning.
However, what I'm talking about is: Replacing those darn Cyliinder Head Steel Plugs with BRASS ONE. These C/H/Plugs have an 7/16" rim around them and the plug sits into the head deeply. Not like the ones on the block.
My problem is I want to replace those suckers with: BRASS ONES. But I haven't found the DEEP SET BRASS ONES WITH THE 7/16ths. in. rim that go deep into the heads.
My search continues, help if you can in locating a supplier that has those darn Brass Head Plugs.
Thanks
GOD BLESS
Schooner :cool:
I believe Pioneer makes/sells them (brass ones).
If need by, you can use a slide hammer with a screw to remove the old ones.
Steel works OK, as long as they are installed with some kind of sealant, and as long as you use antifreeze/coolant that has anticorrosive additives. Of course, you are playing with fire if you are using just water for coolant. It cools well, but it EATS your cooling system.
Lost in the 60's
machine shop tom said:
it's The Attack Of The Zombie Threads!!!!
Tom
I think you are right since the guy was looking for them in October of 2006...........I would think that he has found them by now, LOL. :D :D :D
1 - 13 of 13 Posts
