Just finishing my '55 Bel Air hardtop and am thinking about buying a fire extinguisher to carry in the trunk.
I've been doing a little research and am seeing horror stories about the damage a dry chemical extinguisher can do because the chemical powder is so caustic. It will basically ruin your interior and inside wiring if you use it there.
Under the hood it will basically eat up aluminum, attack anything plastic, corrode the wiring and ruin the paint unless you get the chemical off immediately. Seems like it would be common that you couldn't clean it immediately since the car may not run due to the fire and need to be towed.
So, I am thinking about a halon (they are still available) or a halotron (only about half as effective as halon per unit of volume). There is no residue thus no damage caused by either of these. The cost of a 5lb halon extinguisher is about $210 and a 5lb halotron is about $175 but the halon will put out twice as much fire.
