1 - 19 of 19 Posts
Hi all,
I have an Astro Evo 1.4mm spray gun. I am using 3/8" I.D air hose and I can't set the psi right...it always read at 8 psi with trigger pull..plus I turned the regulator all the way up...the gun stated air in 16-19 psi
I read the spec and it said Air Inlet I.D is 1/4"..
My question is does the air hose I.D matter?
My A.C is 8.6cfm @ 90 5.5hp 30gal
No, NO, you don't want to downsize! You want at big a hose as you can haul around. You want as big of pipe, and as big of hose as you can get away with.
A quarter inch hose is WAY too small for any HVLP gun. You need VOLUME (the V in HVLP) and the larger hose gives you that.
it's not the HVLP. it is an Astro Evo LVLP
The size of your air hose is not the problem. All my guns have 1/4 inch inlets and all my hoses are 3/8's.
You bought a made in Japan spray gun and probably purchased their regulator. The regulator is your problem.
Discussion Starter · #9 ·
As you said I can't use regulator from HF or other brand...I have to buy same brand as the gun?
Discussion Starter · #10 ·
AntnyL said:
What's the cfm rating of your gun with the trigger pulled? Does it exceed the cfm capacity of your compressor?
Spec data said 16-19psi. 9cfm
I have Digital Reg and with the trigger pulled it reads only 8-9 psi with 3/8" air hose
So I went to change air hose to 1/4" and it jump to 20psi
What in the world are you talking about? If you want a decent regulator for your gun go over to Lowes and purchase their 1/4 inch inlet regulator for $14.95 and mount it on your gun. I have one on my primer gun and swear it preforms as well as my Devilbiss regulator on my spray gun.
Do you actually have 3/8" ALL the way from the regulated source? It won't matter if you have a 1" hose if it is choked down by a small or obstructed fitting somewhere between the regulated air supply and the gun regulator. I have even seen Chinese made fittings that were so poorly made and rough inside that even though they may have been for 3/8" they would not flow the equivalent of a 1/4" fitting. Make sure you don't have a restriction somewhere in the system, it sounds as if you do.
Discussion Starter · #13 ·
I have 1/4" fitting and 3/8" air hose...it made by craftsman I believed...
When I switched to 1/4" air hose my guns work very good...so far i have test them and it works very well...I will try to shoot some clear tomorrow to see if i still get milky look...I always get milky look on clear..it seems like it lacked of air..
Discussion Starter · #14 ·
Ok I bought a digital one from H.F..when I was using 3/8" it will never get to 20psi @ the reg..but then I switched to 1/4" I get 20psi with trigger pulled..
For reference.
The 3/8" hole is twice the area of a 1/4" hole.
The hose will cause resistance. A long hose with 1/4" couplers will cause a significant pressure (flow rate) drop. This is a two fold problem as the 1/4" couplers can flow less air and there is friction loss from the long hose.
My experience with my HVLP guns all Devilbiss (mid range gun and a GFG) was a pressure loss when I was using the 1/4". The bumper demon does not need as much air. This gave me very inconsistent results as I would have the pressure and flow for testing and the start. Once the static pressure in the hose dropped the gun did not spray as well since the 1/4" fittings could not flow enough air to supply the gun properly.
Since switching over to all 3/8 couplers I have found all my other tools are more consistent.
Keep in mind I only have 3/8" hose, that is the most common hose and is likely what you already have.
I have also found that the gun regulators may not be able to supply enough flow rate to work on a big gun. Only the better regulators can give you the flow rate. The common ones you find work well on the small guns such as the Bumper Demon.
What type of compressor do you use, what is the airflow stated on the compressor. With a small compressor it will not put out the volume needed to fill a larger diameter hose, that may be why you're getting a higher reading with the 1/4in hose.
The Penny Pincher
I switched to 3/8" couplers and it made a huge difference.
A larger hose than 3/8" made no difference.
It's the couplers that are the bottle-neck.
Look inside a 1/4" female quick disconnect and you'll see the actual
passage for air is choked down more than half.
the hole is only about 1/8" dia.
That's the restriction, switching to a 3/8" disconnect doubles
that opening. Still not as big as a 3/8" hose but more than twice
the volume of air can pass by than a 1/4" disconnect.
I made this and adjust my air at the wall until I get the right amount
at the gun, then I remove it.
Most regulators restrict air flow,
This is truely what I get when set.
acquadigio79 said:
When I switched to 1/4" air hose my guns work very good....
So are you saying that your system works better with the 1/4" hose? There is absolutely no way the 1/4" hose would work as good as a PROPERLY working 3/8" hose. Either you have changed some of the fittings along with the hose and eliminated the obstruction or that 3/8" hose was plugged up somewhere along it's length. Like Shine said 1/4" hose is for airbrushes you need that 3/8" hose along with the proper high flow fittings.
1 - 19 of 19 Posts
