Hope someone can help. 36 Ford 5 window coupe. Are the top and bottom hinges mounted in the same direction? One piece of each hinge is relatively flat while the other piece has a curve to it. I know the curve side mounts on the outside of the door but does the curve side go to the front of the car on each hinge, to the rear on each hinge or do the alternate - top hinge to the rear, bottom to the front?...
