Welcome aboard. Post photo's of your car, if possible!
A way I have found useful to "see" exactly what the brakes are doing, is to find a secure spot to do this in- might be the hardest part of the deal, has to be somewhere that has space to both sides, front and back, no people around.
The surface needs to be smooth, flat and slippery enough that the brakes can be locked up w/o a lot of drama. A beach (Daytona is perfect
), a deserted construction site, where ever.
Drive to 30 mph or so and hit the brakes firmly, then stop and walk back and look to see where each tire locked up. They should be adjusted to where the fronts lock up at the same time, the rears should lock up at some point
after the fronts. Also at the same time.
A few thoughts:
In a situation where you have the car pulling to the left, you will almost surely see that the left side has locked first.
The cause of this can be air in the line on the
right side- the air will compress THEN the fluid will actuate the brakes if any air hasn't been bled from that right side. This causes the left brake to actuate before the right one and can cause the pull to the driver's side.
I'm basing some of what I'm saying here on you having used the power brake booster and MC from the '68 on the original drum brakes of the '41.
Drum brake apps- The springs and hardware that hold the shoes to the backing plate and that serve to return the shoes to an "at rest" position also need to be replaced as a set- both sides at the same time.
The master cylinder for
drum brakes usually have residual valves built in. If you've not installed residual valves (and you are using the '41's front drum brakes), you will likely need to add them. If you have the '68 power brake booster, master
and rotor/calipers, the residual valves could be faulty.
Besides the residual valves, the flexible lines from the chassis to the slave or calipers needs to be replaced if they're original. They can deteriorate internally, the inner lining will actually block the flow of brake fluid when this happens. Also check the clamps that hold the flexible lines from contacting anything- these clamps can get bent or rusted up in their ID and that can pinch the flexible lines.
Drum/shoe or rotor/pad contamination- often a brake fluid-soaked shoe will lock up (grab) before a dry one, and no amount of cleaning ever really restores it back to a "before wet" condition in my experience. Any grease from a bad bearing seal will foul them, too. This can make that brake lag behind the others.
The slave cylinders or rotors will sometimes lag behind each other,
especially if at some point one was replaced and the other side was not replaced at the same time.
Obviously, the adjustments have to be such that the brakes work in unison, but w/o all the components working together at the same time, the brakes cannot work evenly.
