Don`t know where you could buy the box but I would think it wouldn`t be to hard to make one.You could get some sheet metal and cut it in squares to the dimentions of your battery. Then weld it together and find a lpace to weld it to(or bolt it to) your frame. You could also get some bedliner material from the parts store and spray it inside the box to protect the metal and cushion the battery. ;)
Here's a site that shows someone else's solution.
<a href="http://www.geocities.com/jniekamp/ModelA/modela.html" target="_blank">http://www.geocities.com/jniekamp/ModelA/modela.html</a>
Drop down batt box
I'm using the one from Speedway Motors; They have two, one, I believe is stainless steel, the other powdercoated steel. Hope this helps. My Optima battery fits just right. JON
