I'm fairly confident the factory was using a thin steel gasket then that was 0.016 compressed. The bore on those original thin steel gaskets back then - I dunno! Maybe 4.1 on a 350? I'm get .21 ci or 3.46 ccs.
I'm using nominal 9.025 deck height so am using .025 as deck clearance from the piston.
Regardless of bevels, reliefs or not, if I plug in 12 ccs, that gets my '71 L48 calcs real close to the factory claimed 8.5:1 (I'm calcing it at 8.42:1). (BTW I'm pretty disappointed in Desktop Dyno 2000's ability to calc compression - seems way off!)
The '70 L48 was 300hp and advertised 10.25:1 CR. but the same engine in '71 dropped to 270hp and 8.25:1 CR. WHy? 64cc to 76cc heads and flat tops to dished. I've never found any specific references to the '71 pistons being precisely 12ccs but that seems to be where the consensus leads me. I think '72 engines were pretty much identical to '71s w/ respect to pistons/heads but don't quote me.
