Hi Guys;
I am at my wits end hope you can help. Have a 1403 edelbrock carb on a sbc and it to periodically floods out. Here is what I have done Followed the edelbrock book to the letter with all adjustments. cleaned the carb. rebuilt it. new needle valves.three times. the needle valves always seem to partically stick . I would hammer on carb they would reseat, and be ok for a while. Carb pressure with regulator only set to 3 lbs float level a tight 7/16" choke works fine. new fuel filters. insulators on carb base stays cool.The carb has no debris in it. Blew out all passages with air.This carb only has 500 miles on it. I have read the previous posts about the same problem, but still do not have the answer. Thank you for your help.
