1 - 2 of 2 Posts
Air bleeds on my Edelbrock 1406 plug every time I use WOT throttle. This causes a rich rough running condition that doesn't go away until the bleeds are cleaned (blown out). The carb has been taken apart and thoroughly cleaned several times. It runs fine afterward until the throttle is floored. Then, same issue. I've found that the bleeds can be blown out, from above, using Gumout carb cleaner. Again, runs fine until floored. What's going on? After complete cleaning, where's the crud coming from? What's the fix? Just don't floor it? Frustrated. Help!
Banned
Those clog up pretty easily, you need to definitely change your filter and perhaps clean the rest of your fuel system pretty well. If you have e85 rejet your carb for it, run a few tanks, and then go back to gas, it may clean it all up.
1 - 2 of 2 Posts
